Old 08-09-2008, 04:59 PM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Does high humidity climates effect/worsen FE?
I was curious if this has something to do with it..
My FE hasn't been where it usually was when I was in California (Minnesota now)
any incite?
Old 08-09-2008, 05:22 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I've heard people talk about getting better FE right after a light rain, but that's just conjecture and even so, what it really means, I don't know.
Old 08-09-2008, 07:59 PM   #3 (permalink)
any incite?
I've never tried it, but there are claims water injection helps FE if this is true I would think that a more moist air would also be of benefit. Cooler temperatures are another thing you are probably faced with in MN as aposed to CA and you always get better mileage in a warmer climate than in a cooler climate. I can usually tell a difference in FE when the outdoor temperature is in the 80's aposed to the mid to upper 90's.
Old 08-09-2008, 09:23 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Chris D. -
Could it be the gas? Maybe you have a different formula.
Also, I keep thinking of the CAI/HAI example. If Cold-Air-Intake is bringing in colder air, isn't it considered to be more "dense" with moisture?!?!? With the Hot-Air-Intake, the idea is that the air is drier, aka less oxygen, so it's running leaner.
CarloSW2
American Solar Energy Society
Old 08-09-2008, 09:57 PM   #5 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
High humidity improves mileage since water vapor has a lower density than nitrogen, oxygen, or CO2, so high humidity reduces aero drag. It also de-rates the engine's power since the water molecules displace some of the oxygen that the engine could be sucking into the cylinders, so the ICE burns less fuel, also improving mileage.
aerocivic.com
Old 08-10-2008, 03:03 AM   #6 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Things that changed with the move from CA to MN
  • Gas Blend
  • Elevation (overall and variations along your commute)
  • Humidity
  • Average Temperature
Old 08-10-2008, 03:51 AM   #7 (permalink)
EcoModding Minded
Chris D.'s Avatar
hmmm good info..
as for elevation, its about the same as Modesto CA, or not too far off to change anything..
fuel grade and temps defiantly have something to do with it..
I'm going to have to look into a grill block now to get some FE back.
Also I have a nagging suspicion that my plugs are in dire need of replacement..(been a while)
I need to read those and see how thats rollin..
Old 08-11-2008, 02:55 AM   #8 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Cool, humid days seem to offer the best FE -- especially in the morning hours (even with the warm-air intake).
The Physics makes sense.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 08-11-2008, 11:35 AM   #9 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
There are 2 papers on atmospheric conditions impact on ice efficiency in the sticky in the general efficiency forum. According to those papers humidity reduces bsfc.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 08-11-2008, 12:06 PM   #10 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
My own records show a 6% improvement in humid weather vs dry. That's collected over a year and a half, on my daily commute.
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 01:51 PM
High Altitude FE? superchow General Efficiency Discussion 27 06-26-2009 11:35 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
