Old 09-27-2016, 05:18 PM   #112 (permalink)
Macskyver
Thanks - the only thing I am not totally clear on is the bead and cove. You made the 1/4" edges curved so they fit tightly around the curved ribs? You then had to sand the surface, I assume?
I am really liking this construction technique. I have my CNC machine that could cut the ribs - and you used jigsaw joints to join them together, like I did on CarBEN. Nice job!
Thanks. The beads and coves are on the edges of the strips so they fit together tightly with a lot of edge-to-edge surface area contact when laying the flat strips over curves. They also are good at preventing gaps. There's a little leeway before daylight starts shining through. After they are laid down, the curved surfaces are definitely faceted, and require quite a bit of sanding to make smooth.
The Following User Says Thank You to Macskyver For This Useful Post:
NeilBlanchard (09-28-2016)
