Old 10-06-2016, 05:18 PM   #17 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Originally Posted by rmay635703 View Post
Don't wot or over 80% and it won't be hard at all.
Go wot into open loop on an aluminum engine and you can burn stuff
A snoot of either will make it start cold, also auto ether injection kits exist, I'm looking at one now for a cat.
In terms of increasing injector flow rates I would have gone very mild, maybe +10% since most Ecus have a very wide trim to begin with
Aluminium or cast iron will not make any difference unless your engine has exhaust valves made from unobtanium or the piston is cast iron!
Burning of the block or head is secondary to damage caused elsewhere, and is done by the burning gases "blow torching" the passage...
Ether makes my cat go to sleep, not wake up
Simon
