Old 10-08-2016, 02:17 PM   #133 (permalink)
aerohead
cover
Originally Posted by skyking View Post
Phil, you could cover the shell with rips of 1/8" wood paneling, wiring it on with safety wire and epoxying like a stitch and glue kayak. IF you leave a gap and don't butt the strips, and just glue them to the tubes, there would be no facets or edges. Then fair in the gaps with some epoxy goop, sand, and sand off the wires.
It would not be absolutely perfect without a bunch of fairing and sanding, but it would be very very close.
BTW, it is 2048 miles door to door. cheap flights are ~255, and greyhound was 250, LOL!!!
Greyhound is on some serious drugs there.
If I left my right foot out, taped on some fairing, figure 80 gallons round trip
~70$ less than flying
The skeleton is already at the net dimensions so I can't go 'outside' that footprint.If I had infinite time I'd do tooling plaster,make a splash,then do a thin,wet layup inside that.
For the time being,I'm filling the voids with polyisocyanurate foam,will Surform/sandpaper that down,nuke it with resin,then a single layer of glass,then sanding,Bondo,etc.
I'll essentially be taking a 'male plug' to DARKO.
BamZipPow (10-09-2016), skyking (10-08-2016)
