10-08-2016, 08:44 PM
#135 (permalink)
Originally Posted by aerohead
The skeleton is already at the net dimensions so I can't go 'outside' that footprint.If I had infinite time I'd do tooling plaster,make a splash,then do a thin,wet layup inside that.
For the time being,I'm filling the voids with polyisocyanurate foam,will Surform/sandpaper that down,nuke it with resin,then a single layer of glass,then sanding,Bondo,etc.
I'll essentially be taking a 'male plug' to DARKO.
so there is no room for a 1/8" skin over the tubing?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
