Old 10-10-2016, 12:22 PM   #81 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I took it for a shorter spin around the neighborhood other day. The EGR plate cleaning definitely didn't fix the bucking issue, though I'm sure it didn't hurt. I'm still getting some pretty violent bucking. When wound up, I got a flashing engine light as well which likely means misfiring. I'm going to get new plugs ordered up today after I verify the spark plug index codes on the head. After that, if it persists I'll be looking at the ignition coils.
Yep Plugs and coils. (Sometimes they loosen and sometimes grounds do it too)
After that egr valve and Vtec sock
Valve lash too.
In my case my car loves to jerky when it's cold or wet and rainy.
Best improvement was running a $1 vacuum hose shoved into the intake tie strapped so it was near the cat then use s oval bottomed cardboard cutout with duck taped handle.
I have also found when the car won't stop herky jerky that a gallon or two of e85 stops it. Mystery oil helps with hard to solve jerky.
If you just want to drive and put off some of the repairs the above 3 really help.
Good luck
The Following User Says Thank You to rmay635703 For This Useful Post:
Daox (10-10-2016)
