Originally Posted by Daox
Haha, I figured. Do you have any mods planned?
Not really. I'll up the tire pressure... but not to where I'd normally put it. Apparently the TPMS goes nuts over 45psi and has an annoying, repeating chime. I'll probably put them at 40psi cold.
First order of business (well, when I get my garage cleaned out enough I can work in there....) is to address some deferred maintenance items. While it's in good shape overall, there are some things that need attention. Fortunately, I bought it for 25% less than the next cheapest comparable car out there so I can afford to put some money into it.
Known issues that I need to fix:
- Clogged tubes in the sunroof.
- Differential bushing is trashed
- Oil pressure sending unit is giving erroneous readout (always showing 130psi, even with the engine off)
- Radiator leaking.
- No spare tire/jack (actually had one for a different car that doesn't fit)
