So, I've gathered some data from trying out full-out EOC... First off, steering is very tough due to the extra resistance provided by the power assist motor on the steering column, and the brakes suck once the vacuum assist is used up(a vac reservoir may be coming), but there are lots of EOC opportunities on my work commute... Using them all, I've been averaging around 42-43mpg indicated... Wait, that looks like no improvement, except that all week(up to tonight), my commutes were made in forty degree weather(one morning started at 38 degrees)... Tonight, the ambient temp was 52 degrees on my trip home, and I averaged 45.3mpg indicated... To put it in perspective, the last time I got numbers like that on that particular trip, it was 90 degrees outside the car...
To clarify the numbers, the UltraGauge calibration still hasn't been changed, so the actual mileage should be around 10% less...
My current Ecotec project...
![](http://ecomodder.com/forum/fe-graphs/sig10025a.png)
My last Ecotec project...
