Old 10-18-2016, 03:16 PM   #48 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
After some thought, I'd probably put a Bolt motor + battery in my Insight. 60kWh battery should be good for at least 300 miles, and the motor is rated for 200HP / 266ft-lbs of torque. In the 3600lb Bolt, this is good for 0-60 in 7 seconds. The Insight would be closer to 2500lbs with battery, motor and electronics, and have probably half the CdA.
A gasoline car may go 0-60 in 7 seconds at redline in low gear, but an electric has this same power on tap all the time, so it's far more "available". Having had the chance to drive a few EVs, it feels like you're always driving around in 1st gear.
Economy and performance together.
