Originally Posted by Old Tele man
I've owned both and the PRIUS is definitely a better FE vehicle. Only the *manual* Cruze Eco model gets decent milage, the 6-speed automatic definitely had problems in the 2011 vehicles.
The only 5 problems with my 2011 cruze automatic are:
1- horrible entertainment system (buttons not working well). Can be changed with a $500 linux one.
2- tardy transmission (can be solved by shifting manually)
3- low performance over 95F ($500 intercooler replacement solves this).
4- exhaust heat radiating through the bottom center (not a problem in cold environments).
5- lousy AC (keeps up to about 85F. If outside is hotter than 95F, it gets uncomfortably hot inside no matter how you point or set the ac and fan)
Mpg wise I also get 34mpg avg, and 55mpg at 55mph.
