Old 10-19-2016, 06:39 PM   #23 (permalink)
gone-ot
...beats walking...
Originally Posted by ProDigit View Post
The only 5 problems with my 2011 cruze automatic are:
1- horrible entertainment system (buttons not working well). Can be changed with a $500 linux one.
2- tardy transmission (can be solved by shifting manually)
3- low performance over 95F ($500 intercooler replacement solves this).
4- exhaust heat radiating through the bottom center (not a problem in cold environments).
5- lousy AC (keeps up to about 85F. If outside is hotter than 95F, it gets uncomfortably hot inside no matter how you point or set the ac and fan)
Mpg wise I also get 34mpg avg, and 55mpg at 55mph.
Sounds like you had better luck than we did with our 2011 Cruze LTZ. Our specific "headache" problems:
1) Transmission randomly "stalled" engine when making tight lefthand corners, such as "U-turn" at intersection...GM couldn't/wouldn't "fix" anything, even though the 2012 transmission 'mysteriously' got a new/different shift-body calibration.
2) The cabin often reeked of antifreeze for no (apparent) reason.
3) The thermostat housing leaked like a sieve...GM repaired it once, but did nothing when the replacement housing/gasket began leaking (but, PEP Boys could fix the problem!!!)
4) The vehicle NEVER got above 32 mpg (and I'm a quasi-hypermiler!).
5) The Z-bar rear axle linkage "clunked" but GM claimed it's normal.
6) The A/C would suddenly quit while driving for no apparent reason; not good when it's 100F+ outside! GM couldn't/wouldn't fix.
GM is no longer on our shopping list for ANY vehicle.
