Old 10-21-2016, 01:57 PM   #98 (permalink)
MPGeo
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
3rd brake light update
So it's been a week or so since I've installed the LED 3rd brake light, and I have made three changes to the setup.
1 - Modified wiring to include a brake light controller for added visibility.
This allows it to blink 4 times fast, 4 times slow, and then steady until reset.
2- I added a rubber hose to upper end of bracket to cushion bracket against window and eliminate road vibration chatter against glass.
3- Had to add a ground jumper from main body to hatch door. The 3rd brake light would sometimes come on and and sometimes it would not... T/S and found improper grounding through hinges, and grounding through latch. Jumper wire provides constant ground and eliminated the issue.
3rd brake light mod is now officially compete
ID:	20768   Click image for larger version
ID:	20769   Click image for larger version
ID:	20770   Click image for larger version
