Old 10-22-2016, 10:57 PM   #31 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Are they floating on the spring leaves? It appears the bungees snug them up. what locates it sideways, just the front hinges?
You'll need to carry a 4" mirror on a salfie stick so you can show people the underside.
The back end of the belly pan is actually resting on the shock mount plates. The rubber cords keep it snugged up against the shock mount plates although the right side of the slotted angle rests on the right spring hence the rubber hose to keep the squeeks down to a minimum.
Yes, the hinges up front keep the belly pan aligned from sliding side to side. The rubber cords are angled to keep a small amount of side tension as well. The hinges are bolted to the rear crossbeam which is bolted to the truck frame.
The rear diffuser will git new hinges that will bolt into the slotted angle. The pin will git replaced with a stainless steel bolt so the diffuser can be removed without unbolting the hinge from the belly pan.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
freebeard (10-23-2016)
