Old 10-26-2016, 09:41 PM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by daniel831 View Post
A few cosmetic issues, some title/reg. hoops to jump through, also gotta pull the cluster and make sure the check engine bulb is actually in there and plugged in (no CEL w/KOEO). No codes, fingers crossed that it passes sniffer test. Car runs great aside for a bit of synchro grind on the 2-3 upshift, gonna put some friction modified trans fluid this weekend and see if it mellows out.
I have the 3rd gear synchro grind too. Been that way since the transmission swap. I think I put a heavier oil in, IIRC. Problem did not go away completely. But as long as Ishift mellow style and don't race/cram it, it is symptomless really. I am testing a CAT cleaning method. I'll know soon if it worked to improve my CAT i hope.
