Old 10-29-2016, 02:27 PM   #78 (permalink)
jamesqf
Originally Posted by Fingie View Post
Wonder if I should invest into geothermal heat, or whatever it's called in English.
I think you probably mean a ground-source heat pump, not a true geothermal system. (Though they're often miscalled geothermal heating by merchants trying to take advantage of public ignorance.) A geothermal system works on actual hot water (or rock), such as a hot spring, which I don't think you're likely to find in Finland. (At least I don't recall seeing any.)
