Old 10-30-2016, 04:22 AM   #80 (permalink)
MJamson
Renee - '92 Renault 50 Series
90 day: 21.21 mpg (US)
EscortEstate - '97 Ford Escort mk6 ANL
90 day: 37.66 mpg (US)
Originally Posted by jamesqf View Post
I think you probably mean a ground-source heat pump, not a true geothermal system. (Though they're often miscalled geothermal heating by merchants trying to take advantage of public ignorance.) A geothermal system works on actual hot water (or rock), such as a hot spring, which I don't think you're likely to find in Finland. (At least I don't recall seeing any.)
There are a number of different systems like this in Sweden, as I don't really know the names I'll write a short description
Drill a hole about 200m deep into the ground, pump water down to the bottom and warm water comes back up.
Lay a pipe (1 km or so) a meter or so under the ground, and pump water through it.
Lay a pipe (1km or so) along the bottom of a lake and pump water through it.
There is a forth system where a hole is drilled and then instead of water, air is blown down into the hole and the air comming back out is warmed.
I suppose that the best place is find true Geothermal heating is on Iceland, but then it comes at the price of being a little smelly.
