Old 10-31-2016, 11:41 AM   #131 (permalink)
Macskyver
Macskyver's Avatar
Originally Posted by Jeddy53824 View Post
That is gorgeous.
Thanks.
You pour the resin, squeegee over the top of the Mylar and let the resin cure before you peel the Mylar off.
I've done the same thing with paint stripper and 4mm polyethylene. The stripper melts the paint to the poly and when you peel it off the paint comes too. It's much tidier.
How well does that work in practice on large surfaces? I imagine you can't easily get mylar in a large enough single sheet to do a camper shell. Also, how thick are you doing the epoxy? Is it still the multiple thin layers or a single thick layer?
