Old 11-01-2016, 10:07 AM   #13 (permalink)
airfidget
airfidget
Originally Posted by California98Civic View Post
Subscribed. Question: the range between your highest and lowest is kinda wide, like a 15% difference. That's an issue, no? I've been told more than 5% or 10% is a problem.
Also... how is the alldatadiy manual working for you? How extensive is it? Did they mail you a print copy or do you get it in an e-book form too?
Bah! I had my units wrong in my previous post. I'm sorry, I'm an engineer and I use metric all day. All of the units above should be in 100's of kPa.
Also my alldata manual says 28 kPa maximum variation. I tried to be consistent with cranks, cranking 5 times on each, but I could have fudged the last one. I attached photos.
alldatadiy, I definitely suggest a subscription, especially if you have two cars, you can get a discount, and especially if you want to modify electronics, they have very good diagrams of each connector on your vehicles. I have only
[imghttp://ecomodder.com/forum/attachment.php?attachmentid=20806&d=1478004997][/img]
ID:	20804   Click image for larger version
ID:	20805   Click image for larger version
ID:	20806   Click image for larger version
