Well here goes nothing...
I removed those wires and result
AC controller firmware, ver. 1.0
High pedal lockout fault. Ignore this for now. It's not really a fault. haha.
Throttle out of range! Is it unplugged?
When i try to send ? nothing happens. i will try to connect throttle too.
EDIT:
DOH! I tried to send '?' but i just cant. I guess my keyboard is not set correctly. Wouldnt it be good to use other set of caracters that are generaly used. Not a apostrophe! Maybe quotation "?" ?
Could i correct this in code UART.C without consequences?
Well i just had some settings wrong. Basicaly you have to set "hardware flow control" to "none". I got a set of orders now, but i still dont know how to setup throttle...
EDIT2:
Well i figured how to copy paste orders to realterm and i set me a .txt file and every parameter written. So i just pasted to interface and enter. It is now set and i just have to assemble inverter.
A
