Thread: Noob From Aus
Old 11-01-2016, 02:37 PM   #18 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
The bit about the power steering components has a bit of room for interpretation. As written it requires that any installed power steering components have to be in good order, so that rules out the old looping-the-lines trick. It doesn't say that you have to have it.
Obviously you guys in Australia know your road nannies better than I do so feel free to ignore me. But if a concurrent Starlet was available in Oz without PS, doesn't that open the door to removing it from yours? Just install the same hardware that would be on a non-PS Starlet and enjoy the reduced engine load. It wouldn't be stock to your car but it would be a stock application.
[edit]
(reads the rest of the earlier posts)
Sorry, never mind. But I believe there are significant gains to be made there, the engine isn't especially powerful so whatever load you take off it is going to be good for you.
