Old 08-11-2008, 02:56 PM   #1 (permalink)
KJSatz
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
61) Parking tactics: orbit to bleed momentum
If you find you have too much momentum after reaching your preferred parking spot, continue coasting further down the row or "orbiting" a spot until you can roll to a stop in position without touching the brakes.
(The extent to which you might continue 'orbiting' depends on whether your engine is on/off and whether you're driving a manual or automatic. Also, it depends on traffic in the lot, obviously.)
I don't understand this tip. I think it would be better to just use the brakes--or use less gas in the previous pulse. Is the only reason to do this to artificially increase your MPG by keeping the odometer rolling? It doesn't seem like it would actually decrease fuel usage (equal usage with EOC, greater usage if idling in neutral). Or maybe it's all going over my head?
