Old 11-04-2016, 08:48 AM   #2861 (permalink)
WindyDrew
AC Customs car builder
S10 - '99 Chevy S10 Base
90 day: 23.5 mpg (US)
Purple People Eater - '95 Geo Metro LSi
90 day: 34.76 mpg (US)
Volt - '14 Chevy Volt Premium
90 day: 1680 mpg (US)
Why don't you just use the factory resolver?
Originally Posted by arber333 View Post
Here in Slovenia at firm RLS they offered me an encoder replacement for my Leaf motor resolver sensor. Huh! I like to think out of the box...
I went on and took the back of the motor apart. Pictures show what i got.
There was a lot of bolts to loose. I even had to borrow a torx key to unscrew a bolt that doesnt have an edge to hold. I replaced it with normal bolt the instant it was loose .
I got resolver out and checked crevice. Well i could mount a rotating magnet inside aluminum fitting on the end of the shaft. I could fasten that as M12 nut with extension.
Then if you look closely the cover is made of two parts. First is just a final cover, but second has two holes on the left that are threaded and currently of no use. I would use this as my anchor for mounting encoder PCB. It is magnetic encoder with open collector NPN output pulse. I would use a pullup to 5V with it.
Rotary magnetic module on metal flange RMF44
Not so much expensive... I would use current connector and after cover is on you couldnt tell the difference.
Now the question to whom it may concern:
What encoder sensor would be best for our inverter/motor combination? Either 9bit (512ppr) or 10bit (1024ppr). I can get either one, there is no price difference. I just want to know if something is better than other?
tnx
A
