Old 11-07-2016, 11:25 AM   #2867 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Originally Posted by arber333 View Post
On the R to E board i see also the GND pin on the input. Do you use it at all?
And on the output, how do we use DOS, DIR and LOT pins? Can i just use A, B and I pins besides 5V and GND? I would like to install 5Pin connector.
A
Yes, just ignore the ground pin on the resolver side. I dont' think it's necessary. It was in case there was noise, but the lines are so low impedance (like 16 Ohms DC resistance) that I don't think it's worth using a shielded cable, and grounding the drain wire. At least I've never had any trouble getting it to work. Also, ignore the DOS/DIR/LOT pins. Just use a 5 pin connector for +5v, ground, A,B,INDEX.
kits and boards
