Old 11-07-2016, 02:24 PM   #133 (permalink)
Macskyver
Macskyver's Avatar
This last weekend I finished up doing the exterior varnish. I was originally going to do 10ish coats, but after reading the varnish technical data sheet a little closer, I found that only 2-3 coats over epoxy is enough for proper protection. After all was said and done, I ended up with 6 coats over the exterior with 4 coats under the eaves. This should be more than enough, and I can always add more at a later date.
Next up will be the installation of the windows. I still have a few aluminum pieces to design and cut out for this, but that shouldn't take too long.
The Following 7 Users Say Thank You to Macskyver For This Useful Post:
BamZipPow (11-07-2016), bespurcell (11-30-2016), ByDesign (12-18-2016), Daox (11-11-2016), KamperBob (11-08-2016), NeilBlanchard (11-08-2016), skyking (11-07-2016)
