Originally Posted by jamesqf
Who knows what will happen after 10 or 20 years?
The engineers know. The newest LiNMC chemistries will easily make 1000 cycles to 80% and that is with deeper cycling during testing than what will be programmed into any final product. More like 2,500 to 70%.
Types of Lithium-ion Batteries
LiFe A123 cells essentially last forever if you use them in the 70% range of charge and and low voltage cut off.
http://www.formula-hybrid.org/wp-con...sign_guide.pdf
