Old 11-09-2016, 10:06 AM   #7 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
potential crank pulley issue
Yes! I've read about that - somewhat scary.
The keyway on the end of the crankshaft can be destroyed if the crank pulley bolt (a) simply loosens over time; (b) or was re-torqued incorrectly after removal; (c) or the key was inserted backwards in the keyway on reassembly.
The result is the crank pulley develops a wobble that wrecks the crankshaft end = need new crank/engine.
I will be looking for evidence of this:
Resulting damage:
^ That should be a clean, straight keyway.
It's a fatal flaw in the 1.6L 1st gen engine with the "short nose" crankshaft pulley end.
There's also a "loctite fix" procedure that may work if the damage hasn't progressed too far.
Xist (11-09-2016)
