Originally Posted by compdrag
Ok so I added some coroplast to the underside of my car under the engine and transmission. I have about an inch gap between it. Will it be ok for heat?
For a syn-lube package,General Motors is allowing:
*239-degrees @ coolant
*284-degrees @ engine oil
*221-degrees @ ECU
*338-degrees @ brake fluid
*284-degrees @ transaxle
with -22F-degrees,to 122F-degrees
