Originally Posted by Fingie
Got the job.
Well done
and blocked the grille partially. Temps rose significantly. I was even forced to open up the block a bit, it was too effective
Most have to do several versions before they find what is right. That is why I have several and I swap them. The one I have now works well from 10*C down to around 0*C, the engine temp has been a bit low this last week but as it is predicted to get warmer this week comming it is staying on.
