Old 11-14-2016, 06:04 PM   #5 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by KnifeKnut View Post
Couldn't I get a good idea as to what the Fuel air ratio is doing by looking at the oxygen sensor voltage? I really would like the added gauges when I upgrade to a newer Honda. Also, unless I am going for maximum power, I do not need to know the fuel air ratio if I am getting a calculated mpg reading, right?
Unless you've got specific plans otherwise, the AFR will just flash back and forth around 14.7. It's of limited use really as that's what the ECU is for. The only possible gain is you would know exactly when fuel enrichment is occurring, but that's less important on a NA engine - you'll probably find the open loop indicator is all you need.
SGII does perfromance measurements and reads "ability to access manufacturer parameters, if manufacturer codes are known", they call it Xgauge.
