All solved. I needed 33450 vss pulses / mile. I confirmed that the speed was accurate with my phones GPS. I think the reason it needs to be so high is because the wire I tapped into is the vss signal after the vss signal amplifier. The mpg values look mostly accurate at the moment.
Thank you everyone
