Old 11-25-2016, 11:53 AM   #11 (permalink)
Yellow - '88 Honda Prelude
I I decided to go another route. I read another option was to connect it to the speed sensor wire behind the dashboard. I am now getting a speed signal. The problem now is that the speed is greatly exaggerated. 5 mph = 25 mph and 60 mph =160 mph.
Maybe it just needs calibrated. I am not sure.
to connect it behind the dashboard. I am getting a signal
Old 11-25-2016, 01:00 PM   #12 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
assuming you haven't picked up the tach signal, then yes...it should just need calibrating.
Not sure on the older models, but it looks like a lot of Hondas use ~8204 pulses per mile. If yours is different, I'd change it to that for starters.
Old 11-25-2016, 05:38 PM   #13 (permalink)
All solved. I needed 33450 vss pulses / mile. I confirmed that the speed was accurate with my phones GPS. I think the reason it needs to be so high is because the wire I tapped into is the vss signal after the vss signal amplifier. The mpg values look mostly accurate at the moment.
Thank you everyone
honda, mpguino, prelude, vss
