Old 11-30-2016, 04:50 AM   #31 (permalink)
briantrice
Originally Posted by Grant-53 View Post
Fred Hayes uses the Airtech dustbin and tail section on his Vetter Challenge diesel bike. Some of the other riders noticed he had some wobble at speed so a bit of vertical fin might be useful. Check with low&slow for his input.
Right. He had the MV Agusta fairing:
http://www.airtech-streamlining.com/.../MV1751965.htm
http://www.craigvetter.com/pages/201...Challenge.html
I'm using the DBL2 featured on the CB750:
CB750 CAFE BAGGER DUSTBIN SADDLEBAGS SINGLE OVERHEAD CAM, CB 750, SOHC STREET TRACKER, DIRTTRACK, DIRT TRACK
I mainly picked it because it's already designed around a cutout, and I have the Zero DSR which has a high mudguard by default and wanted to have a fairing that didn't require fundamental frontend rework. Once we started mocking it up, it's been clear that the mudguard swings just underneath it relatively easily, and I'll likely use spacers to push the mudguard down a bit more and bake up some polycarbonate to fill in the cutout in front of the headlamp.
I did manage to show up for the 2016 Vetter Challenge at the Corbin factory, using my windscreen. I *believe* I placed third to David Ewart on his Zero S and Vic Valdez's streamliner, which was fine as a first showing, especially since I was still using the off-road-oriented Pirelli MT-60 tires that came with the bike and no wheel covers. There were also a lot of headwinds and high speed running and I tried my best not to tuck to see how well I could do that way.
I've since replaced my rear tire with a 90/10 Metzler Tourance Next and will get to the front when it wears down... some day... Zero tires wear down very slowly.
