Originally Posted by briantrice
For the record, I'm only a Supercharger customer who does technical documentation and testing in exchange for early access. But yes there's a V2, I've seen a prototype and looked over the specifications and sourcing, and it has a much better story all around. I think it'll be much more quickly deliverable, too.
Saw some new specs on the other forum and it looks promising, the possibility to maybe charge above 1C would be amazing.
So, the rear ABS plastic has been reasonably robust and I've had CAD drawings for fabrication for a while, but my front set were shattered by a rock at highway speeds, which was quite concerning and that's why you see Coroplast in my photos. The Zero front wheel for 2015+ models has 5 stanchions supporting the brake disc on one side as well which makes fitment trickier.
I've decided based on this to make a custom Moon disc order and will clear the stanchions by drilling holes. I'll probably line the edges with rubber trim and backing with a little foam to reduce wear, but I need to work out how to mount them against or through the cast wheel robustly. Probably stainless steel bolts of the right length with nyloc nuts and nylon washers. Any thoughts?
Ref Starburst Motorcycle MOON Discs - 16"
Hmm I'm holding off moondisks for the moment, I live in an area that has gusty storms. Even on my XJ600 with top case I sometimes have to struggle to stay in my lane.
Originally Posted by Grant-53
Fred Hayes uses the Airtech dustbin and tail section on his Vetter Challenge diesel bike. Some of the other riders noticed he had some wobble at speed so a bit of vertical fin might be useful. Check with low&slow for his input.
Right. He had the MV Agusta fairing:
MV AGUSTA ROAD RACE DUSTBIN FAIRING, SEAT, FENDER, CAFE, SINGLE, 175, disco volante
2014 Craig Vetter Fuel Economy Challenge, Vintage Days
I'm using the DBL2 featured on the CB750:
CB750 CAFE BAGGER DUSTBIN SADDLEBAGS SINGLE OVERHEAD CAM, CB 750, SOHC STREET TRACKER, DIRTTRACK, DIRT TRACK
I mainly picked it because it's already designed around a cutout, and I have the Zero DSR which has a high mudguard by default and wanted to have a fairing that didn't require fundamental frontend rework. Once we started mocking it up, it's been clear that the mudguard swings just underneath it relatively easily, and I'll likely use spacers to push the mudguard down a bit more and bake up some polycarbonate to fill in the cutout in front of the headlamp.
I did manage to show up for the 2016 Vetter Challenge at the Corbin factory, using my windscreen. I *believe* I placed third to David Ewart on his Zero S and Vic Valdez's streamliner, which was fine as a first showing, especially since I was still using the off-road-oriented Pirelli MT-60 tires that came with the bike and no wheel covers. There were also a lot of headwinds and high speed running and I tried my best not to tuck to see how well I could do that way.
I've since replaced my rear tire with a 90/10 Metzler Tourance Next and will get to the front when it wears down... some day... Zero tires wear down very slowly.
I'm working on a non-dirt front fender for the DS now, I'll post some stuff when I got results.
Here's my bike as it was set up the day of the challenge.
I had a slightly compromised Givi rack at the time (insurance replaced this rack with a new one on my 2013DS when a car knocked it over pretty hard) and I'd quickly mounted it on the DSR the night before with my Bags-Connection Aero cases, which I like quite a bit and are reasonably aerodynamic. I bought those originally for my V-Strom after noticing the mileage penalty I was paying for the stock TraX case kit Suzuki was selling (TraX reduced 58mpg to 48mpg in headwinds at 65mph, Aero brought it back up to 55mpg).
I've since installed a wider sturdy Happy Trails rack to support a tail or something, but it'd be nice if there were really slim aerodynamic side cases to bolt on, or even slimmer cases to bolt to the inside of the rack and have the outside frame a tail.
Come to think of it, it was seeing Vic's bike in detail that day that inspired me to start with the wheel covers.
Those bags do look good as a temporally solution.
Originally Posted by jkv357
That's interesting. That fairing was designed for Land Speed Racing (LSR), so you would expect it to be extremely stable as speeds increase - especially in that range.
Could be some side winds I guess.. That's on of the main reasons for me not to go dustbin.
Current to list:
- Work on the new front fender
- Find a sealed led headlight that is slightly below 7 inch(the hole in my fairing is a 16,4x16cm oval)
- Find some led indicators for the front side
- Drop stuff at shop
- Wait
- Enjoy more comfort and hopefully a better range.
