Old 12-03-2016, 05:39 AM   #85 (permalink)
serialk11r
Originally Posted by Daschicken View Post
That's right...Well, except you have electric power steering, so it doesn't hurt that much.
Forgot to mention that I am back working at an auto shop. I love lifts.
Attachment 20986Attachment 20987Attachment 20988
Stock
Attachment 20990
Modified
Attachment 20989
It draws as much power as headlights do, and it's easy to forget that I have the key in the "ON" position, so I'm little worried about running the battery down by accident. Now, I do have a big heavy lead acid that I am itching to replace with lithium ion so maybe that's not as bad as I think
The delete removes 10lbs from the car which will boost acceleration by 0.4%, but the bigger benefit is that the steering feel and weight will improve a lot. There is way too much steering assist, which makes the car rather twitchy because it has a short wheelbase combined with a 13:1 rack.
Looking at your pulley diagram, the idlers are supposed to ride on the smooth side of the belt but now you're putting the toothed side on the first one coming off the crank (going clockwise)? Shouldn't you have gotten something a few inches shorter and skipped that idler pulley?
