Old 08-12-2008, 08:45 PM   #33 (permalink)
iHero
Originally Posted by almightybmw View Post
I've seen this idea before, never got far though. I think it has good merits, simple design, easy to implement. But I don't worry about the belt. If they can make a belt designed to handle 250hp (CVT on Audi's) then the 5hp assist you want should be fine. I'll even bet you could put a 3-5hp motor on there, and get a high quality stock AC belt to match. Simple, no trying to find the right size or mess with the crank pulley (v-belt vs. ribbed).
@ iHero: Looks like your friend bolted a pulley to the crank pulley, since its a serpentine belt setup stock. Curious if there are detailed pictures of that install.
Another random thought I haven't read above: rpms. what range do you want it to be active, the whole engine's range or just a small range? A small range makes for a cheaper motor and you can use pulley sizes to adjust the TQ to the ICE.
hm. Now I want to do this on my GP, just go find the supercharged 3.8 pulley parts and use them.
I've got more pics of Hoff's HYBRAD -- how do I post them ?
Yes -- I think belts are strong enough/ won't slip for a 5 HP motor -- but I'd prefer a version with grooves. But will a bigger motor fit under the hood -- or do you need a scoop/buldge in your hood?
Regarding RPMs -- this is a crucial issue whether you are building an internal or external hybrid adapter. Are you going to want to vary the RPM? then you'll need an expensive controller and likely a feedback loop like cruise control / PID controller. If you are going to just help from a stop --then you'll need the motor to kick off at a certain RPM.
My buddy picked his highway cruising RPM and used a single control voltage to power the motor. He didn't spend much time experimenting with different pulley sizes to maximize MPG.
