Old 08-12-2008, 09:07 AM   #31 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
I've seen this idea before, never got far though. I think it has good merits, simple design, easy to implement. But I don't worry about the belt. If they can make a belt designed to handle 250hp (CVT on Audi's) then the 5hp assist you want should be fine. I'll even bet you could put a 3-5hp motor on there, and get a high quality stock AC belt to match. Simple, no trying to find the right size or mess with the crank pulley (v-belt vs. ribbed).
@ iHero: Looks like your friend bolted a pulley to the crank pulley, since its a serpentine belt setup stock. Curious if there are detailed pictures of that install.
Another random thought I haven't read above: rpms. what range do you want it to be active, the whole engine's range or just a small range? A small range makes for a cheaper motor and you can use pulley sizes to adjust the TQ to the ICE.
hm. Now I want to do this on my GP, just go find the supercharged 3.8 pulley parts and use them.
Old 08-12-2008, 11:42 AM   #32 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 52.44 mpg (US)
Speaking to powered trailers:
EV Pusher Trailer
This guy has a long journal describing his experience with a homebrew pusher - I especially love how his first iteration used a manual (!) whose clutch was operated by a remote-controlled dealie powered by a cordless drill.
Old 08-12-2008, 08:45 PM   #33 (permalink)
I've got more pics of Hoff's HYBRAD -- how do I post them ?
Yes -- I think belts are strong enough/ won't slip for a 5 HP motor -- but I'd prefer a version with grooves. But will a bigger motor fit under the hood -- or do you need a scoop/buldge in your hood?
Regarding RPMs -- this is a crucial issue whether you are building an internal or external hybrid adapter. Are you going to want to vary the RPM? then you'll need an expensive controller and likely a feedback loop like cruise control / PID controller. If you are going to just help from a stop --then you'll need the motor to kick off at a certain RPM.
My buddy picked his highway cruising RPM and used a single control voltage to power the motor. He didn't spend much time experimenting with different pulley sizes to maximize MPG.
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 04:24 PM
Camry hybrid selling at record pace SVOboy Hybrids 31 05-27-2012 07:32 PM
Malibu Hybrid bennelson Hybrids 17 12-21-2011 11:57 PM
Sat, May 10, Houston Hybrid and Hypermilers Club Dan. Hypermiling / EcoDriver's Ed 3 05-10-2008 04:19 AM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 02:09 PM
