Old 12-09-2016, 05:40 PM   #21 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Basic concept.
Edit: I just noticed I made an error when I made that picture.
The best way to pump coolant through the cooler is something called "counter flow", which is opposite of what I showed.
You want the exhaust and coolant or water flowing against each other.
Only issue here is that the exhaust gas will not want to flow through the restrictive EGR cooler instead of the open pipe. You will need a restriction in the main pipe to force the flow where you want it.
Simon
