Old 12-09-2016, 09:24 PM   #42 (permalink)
cRiPpLe_rOoStEr
Originally Posted by gumby79 View Post
2028 Extreme 800Kv Brushless Motor
This 10hp RC motor is rated at 12s (series x4.2v =50.4v x 800kv = 40,320 rpm and a max rpm 45,000.
10hp burst( 60sec)how long do you expect to be wide open this seems long enough.
with the standard 50% derate for continues is a potential of 3kw of recovered electricity
Are you sure it could work as a motor-generator, in a way similar to the starter-generator units still used in some small aircraft? Anyway, you would need to keep it somehow protected from the excessive heat irradiated from the turbo.
Roster the link is not working says under construction.
Search for the Isuzu Ceramic Aska that you're gonna see some pictures and drawings, even though they don't provide accurate info about the regenerative setup.
