Originally Posted by Occasionally6
On this one - 1.0 liter ecoboost - the need for fuel enrichment is avoided; it runs stoichiometric throughout the load range. At least in part this is due to the exhaust cooling in the exhaust manifold integrated with the cylinder head.
That's not possible. You MUST run richer fuel ratios when you are in boost. No amount of tricks or gags can prevent this. Maybe. MAYBE at 1 and 2psi you can get away with 14.7, but no more.
