Old 12-12-2016, 07:26 PM   #14 (permalink)
jakehammer2000
HP economizer
Originally Posted by California98Civic View Post
Those rules and your riding conditions seem to suggest that you could expand the top portions of the fairing to screen shoulders and more of your head. And I suppose leathers with a larger aero blister behind the helmet would help too. I doubt anything above the front wheel is worth it. Are there no rules about the rear wheen and the tail?
The rules for that section are that the tail and fender will extend at least to the rear axle, so they were only setting a minimum rather than a maximum. I think I could extend the tail to end exactly above the rearmost tip of the tire without causing a commotion and failing an on-the-spot "new rule" during tech inspection.
Sorry, new users are not permitted to post links in their signatures.
