1)Do they require a stock front finder? Or can you simply make a bigger finder ,cover more tire/wheel . The way i read it you you can not enlarge the findder but you can build a 1pice larger finder. I am gessing that this rule is to maintain airflow to the main brakes.. So make shure your brakes are not compromised by adjustments to shape and size.
1b) depending on the end results, has potential.
2)The fairing on your back is the basic shape I'm referring to. Make it come up to the bottom of white strips down to the seat and back to tip or beyond of the bike . It would be part of you, aka not obstructing in the view of the rider. The other benefit would be that it would work in the corners moving with you when you shift to lean off paint.
Can you post a link to a pdf rule book or web site . TY.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
