Damn, you have done some serious work. Excellent job! A few questions. Was the aluminum scrap? What material is the belly pan made of aluminum or coroplast? Have you had any heat problems covering the exhaust? How long did that job take?
Glad to see you used solid concrete blocks under the tires. I have seen people use the others and collapse without warning. Lucky no one was under the car.
Bookmarked your photobucket page.
