Old 08-13-2008, 08:23 AM   #5 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Originally Posted by Wonderboy View Post
when I press the a/c button, the compressor does seem to make an "engage" sound and the tach doesn't drop (which leads me to believe that the compressor isn't broken, or else the rpms would drop visibly when engaging the a/c... right?), but it doesn't cool. I think maybe it just needs to be recharged.
Assuming the "engage" sound is the AC compressor's clutch kicking in, the fact that rpms don't drop visibly indicates it's not seized - it may still be broken.
Use a thermometer in an AC vent to check for temperature change while running it for 5 minutes with the AC on and engine @ 1200 rpm or so. If there is some degree of cooling, a simple recharge may (or may not) do the trick. If no termperature change at all, expect to buy parts.
Better yet, test drive it over to your favorite mechanic and ask for a quick guestimate.
Good luck.
