raceprops, the problem is "claims" vs testing.
I am pretty much familiar with Covey, Pogue, George Wiseman and others. They keep making "claims". Anecdotal customer claims can be indicative, but are hardly tested facts.
If you have a secret device you are working on and are not willing to divulge in a public forum ( and you should not ), then I suggest you find a proper development firm and have them sign an NDA and look over your ideas for technical help. There are dozens of them in your area, in all likely hood.
This forum is familiar with lean burn and the advantages it can provide.
This forum is familiar with hot air intakes and some of the cold start and expanded volume advantages it can provide.
This forum is familiar with detonation conditions and it's extension to HCCI engines and the advantages it provides.
This forum is familiar with gas vapor phase fuels and the percentage of thermodynamic advantage it can provide ( the elimination of an irreversible energy loss ).
Vapor Phase fuel systems use the above principles to operate and extend them to more complex interactions depending on design. If you want to move forward, you must understand all of the above and then build on it.
