Originally Posted by straight5
I drive 58 miles a day, Monday - Friday. About 80% of the drive is highway or interstate, and very few red lights. There is no charging station at work. I'd been wondering if I could stretch the range on a 2011 - 2013 volt that far, but it doesn't sound like I could.
In the volt, does the engine run only when you get down to a predetermined state of charge, or do you have some control?
The car will simply run on gas once you run out of EV.
If you air your tires up, have 50+ degree weather, leave climate control off and keep your highway speeds low you should easily hit 50 miles on electric.
That's 8 miles of gas which should be less than a quarter gallon of fuel.
If you have 80+ weather, idle the car plugged in 10 minutes, leave all accessories and lights off, take surface streets so you can keep speeds below 35mph, use all hypermiling techniques, keep your kwhr/mile above 6 miles per kwhr (2013+ kw gage helps), keep tires above 50psi, accelerate slowly using 20kw or less
And you should exceed 60 miles ev.
On a 2013 you can command gas use any time using hold mode
![](http://ecomodder.com/forum/attachment.php?attachmentid=21080&d=1482338152)
