Old 12-07-2016, 01:32 PM   #121 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by cowmeat View Post
Added another mile to the estimated range I get on a full charge this morning.
I now get 11 more miles of estimated range than I did when I bought the car a couple of months ago. It started out showing the standard 35 miles of range, so I'm pretty sure the lady that owned it before me wasn't a hypermiler!
You will keep improving, my recommendation if you can take the ride, is to bump the tires up to the full 52psi, usually that gains you a couple more miles
Oddly your tires wear better too.
Also you can defog the windows without using much heat, just set the defroster for a low temperature and it will still defog but not use much juice to heat anything.
Also another option is to "idle" your car a 10 minutes, set it to eco, defrost, fan to low and plugged in and you should see minimal loss of capacity but it should get your heater core warmed up.
The Following User Says Thank You to rmay635703 For This Useful Post:
cowmeat (12-07-2016)
Old 12-07-2016, 06:17 PM   #122 (permalink)
I preheat my car about 30 minutes before I leave. The battery will get warmed up for range, but shouldn't cool down much before driving. The extra 15 minutes (pre heat is active for 15) is to allow the battery to top off again.
I just aired back up to 45 psi. Today was our first day below actual freezing.
The Following User Says Thank You to Hank1510 For This Useful Post:
Old 12-07-2016, 06:53 PM   #123 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I need to read up on how to do it remotely. I think there's a button on the remote that does it but I haven't tried it yet
Old 12-08-2016, 03:42 AM   #124 (permalink)
You can press lock, then hold the remote start button for for 3 seconds.
I guess they don't want to remote start the vehicle in a garage if someone sets something on their key on the kitchen counter
cowmeat (12-08-2016)
Old 12-08-2016, 12:45 PM   #125 (permalink)
cowmeat's Avatar
Maverick Hybrids
Do you know if it starts the ICE or the elecrtic? I just need the defogger to work before I get in the car while it's still charging, but I sure don't want to use any gas to do it
Old 12-08-2016, 01:45 PM   #126 (permalink)
I have a 2014. In my menu options, there's a "allow engine to run when charging to precondition" yes/no.
I suspect yours would have a similar option. It's for cars charged in a garage.
Old 12-08-2016, 05:13 PM   #127 (permalink)
cowmeat's Avatar
Maverick Hybrids
I'll check mine, but I'm not sure the 2012 menu is that sophisticated. I don't remember seeing anything like that when I set up the charge schedule, but I was kinda out of my element, I've never had a car that needed programming!
Old 12-08-2016, 06:43 PM   #128 (permalink)
It's in the main settings menu under climate control I think. Not very intuitive.
cowmeat (12-09-2016)
Old 12-21-2016, 09:17 AM   #129 (permalink)
EcoModding Learner
nonikname - '99 Saab 9-5 2.3t
90 day: 33.71 mpg (US)
We bought my wife a 2013 Prius back in the spring. I considered a volt, but she is driving about 60 miles a day and I don't believe they have a charging station where she works. I just wasn't sure how well it "fit" with her habits / anti-hypermiling driving style.
Wondering about a volt for me, because I need to replace my Saab turbo 5 speed. I drive 58 miles a day, Monday - Friday. About 80% of the drive is highway or interstate, and very few red lights. There is no charging station at work. I'd been wondering if I could stretch the range on a 2011 - 2013 volt that far, but it doesn't sound like I could.
In the volt, does the engine run only when you get down to a predetermined state of charge, or do you have some control?
1999 Saab 9-5 sedan 2.3t 5speed
2013 prius 3
"God is a God who both created the universe, and also had a plan that included me as an individual human being. And that he has made it possible for me, through this series of explorations, to realize that. It is not just a philosophy, it is a reality of a relationship. "
Francis S Collins - director of the National Human Genome Research Institute
The Following User Says Thank You to straight5 For This Useful Post:
Kimonoskunk (10-24-2017)
Old 12-21-2016, 09:35 AM   #130 (permalink)
I think that is how it is programmed . I have read it is suppose to transition from battery to gasoline seamlessly .
Suppose to do very well on gas , when in gas mode .
God bless
Wyr
