Old 12-23-2016, 01:38 PM   #6 (permalink)
Harlan
Those things like to run rich at least under boost.
They do, but a lot is unknown about tuning. I plan on finding out if there is a range of timing where they like to run lean as well
Originally Posted by Daschicken View Post
Do these things inject oil with the fuel, like a two stroke engine? If that is the case, make sure to modify the oil supply to get the same amount of oil as before lean burn.
They don't inject the oil with the fuel, but they do inject it directly into the combustion chamber. In fact some people modify the oiling system to use two stroke (as it burns cleaner).
I have complete control of oil injection with my tuning setup, so it's not a worry.
