Old 12-22-2016, 05:37 PM   #1 (permalink)
Testing Lean Burn on my RX8.
I'm currently working on tuning for lean burn on my Rx8 with the end goal of 40+ MPG from a stock MPG of around 20. Here is a video on why I believe lean burn will work well on the rotary engine, and how you gain efficiency as you go lean.
Yes I could start with a different engine, but where is the fun in that! I'll post more as I get more data.
I done a few different tests so far and I will be posting video and results as I get it edited. So far I've seen a 20% reduction in indicated fuel consumption in idle, but I have not run the test long enough for solid data, nor is data at idle that meaningful anyway. I will be live tuning in cruise when I can get everything set up and recruit a helper.
The Following 4 Users Say Thank You to Harlan For This Useful Post:
iveyjh (12-23-2016), Joggernot (12-23-2016), oldtamiyaphile (12-23-2016), pgfpro (12-23-2016)
Old 12-22-2016, 10:51 PM   #2 (permalink)
Those things like to run rich at least under boost.
Old 12-23-2016, 02:00 AM   #3 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Great vid!!!
Looking forward to your findings. I have been running lean burn for about the last 10 years on a few of my cars. My most recent is my highly modified Talon. Check it out some time.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-23-2016, 02:03 AM   #4 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Do these things inject oil with the fuel, like a two stroke engine? If that is the case, make sure to modify the oil supply to get the same amount of oil as before lean burn.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 12-23-2016, 09:24 AM   #5 (permalink)
No they would never meet emissions even in china if they injected 2 stroke oil into the combustion process.
I have seen RX7 engines that were modified for racing to use 2 stroke oil, they smoked like a gigantic 2 stroke chain saw or weedeater.
Old 12-23-2016, 01:38 PM   #6 (permalink)
They do, but a lot is unknown about tuning. I plan on finding out if there is a range of timing where they like to run lean as well
They don't inject the oil with the fuel, but they do inject it directly into the combustion chamber. In fact some people modify the oiling system to use two stroke (as it burns cleaner).
I have complete control of oil injection with my tuning setup, so it's not a worry.
Old 12-23-2016, 02:20 PM   #7 (permalink)
Dark Egg - '12 VW Touraeg
Do any of these words embarrass you... Wankel Rotary Engine?
Old 12-23-2016, 03:17 PM   #8 (permalink)
Just be carefull these engines don't seem like they stand up to detonation and pre-ignition as well as piston engines.
Old 12-24-2016, 09:24 AM   #9 (permalink)
Rotary engines don't like sustained heavy (audible) detonation, but mild detonation at light loads isn't a big issue. At least I haven't found it to be a big issue.
I am running ion sensing for both detonation detection and PPP detection. And it can easily pick up mild detonation. I'm setting it up to both pull timing and reduce boost pressure when detonation begins, I may set it up to add more water as well.
Old 12-29-2016, 11:47 PM   #10 (permalink)
Here is the actual first lean burn test. As you can see it does reduce fuel consumption at idle, but it does not match up to my mental model. Need more research.
lean burn, rx8
