If you just drop it into gear, you will wreck components. If you just touch the clutch plate to the flywheel--hardly even feeling the contact a lot of the time--you will not wear out components. For proof all I have is my car. It has the original 1998 Honda clutch, I know because I bought it from a dealer in Virignia, certified used, in 2001. The car now has almost 250k miles on it. Same clutch. I have been bump starting it using 5th, 4th, 3rd, and sometimes even 2cd gear maybe 50 or 60 times a day minimum every day of the week for 5.5 years and about 75k or 80k miles. Still drives great.
Using the starter. Since I shut down at all significant stops (not stop signs), I also use the starter a lot. 20 times a day maybe? Still using the 1998 starter motor.
It just keep going, and going, and going....
