Welcome! Great story about discovering the car. I bought my current Civic in 2001.
I did not notice a mention anywhere of a vacuum gauge as a way to improve P&G. You really want your pulse to be in a quite narrow range of roughgly 75% engine load. Some sort of gauge is utterly necessary to doing that with precision. Also, with your super tall gearing and lean burn capability, P&G in freeway conditions will not benefit much. In fact, you likely do worse with P&G on the freeway if you do not have a vacuum gauge to help set the most efficient pulse.
